Tinpusher1
- Mar 28, 2013
- 13
I recently purchased a 1995 neptune 180 cc. This boat came from the factory as a one battery boat, what I mean by that is all electric devices ( including tilt and trim bilge etc) are connected to a single battery. When I installed a 55lbs thrust trolling motor I thought it would be a good idea to connect all the electronics on the new deep cycle trolling battery leaving the cranking battery to the motor only. The boat has two sets of cables going to the cranking battery, one for the starter, and the other smaller set of wires to power everything else. The genius that I am (lol) thought this would be easy. Take the smaller leads, add an extension and connect them to the deep cycle battery. Well, to my surprise, when I connected the smaller set of leads to the new deep cycle battery the tilt and trim stopped working. It appears that a circuit is not complete when connecting the leads this way. Once installed back on the cranking battery with the starter leads the tilt and trim work again. How can I fix my boat so that tilt and trim,bilge, bait tank, etc work from the deep cycle trolling battery and the cranking happens from a cranking battery? Also, if I cannot do this, will I fry something by connecting a second battery to the first. Will this make the boat a 24volt system or a big 12volt system. Connecting the batteries in series does not sound right to me! Thanks in advance.
