Conflicting timing specs
Dave1027
I have a '88 100 hp 4 cylinder 2+2 Merc that has two different max timing specs listed. My Merc manual has it as 27 degrees BTDC @cranking speed on one page and then 25 degrees on another. Both pages say the timing is retarded to 23 degrees BTDC @ 5000 rpm. I would think that the 27 degrees is a typo but there is a sticker on the front of the carb cover that says 27.
So which is correct?
Faztbullet
Re: Conflicting timing specs
Maximum Timing @ 3000 RPM.....23 B.T.D.C.
(@ Cranking Speed).....25 B.T.D.C.)
Idle Timing 2 - 4 B.T.D.C.
Dave1027
Thanks for that confirmation.
Do you have any idea why the factory sticker on the front of the motor says 27? Could it be because '88 was a first year for this design?
Faztbullet
Likely but fuels and engine design has changed since 1993, the pre-93 engines are 105 CID and the 94-up are 115 CID
verado7
the 27 deg. is for timing in a test tank
you set it timing 2 deg. less when using the cranking speed method as a safe measure to not exceed 27deg. at 3000 rpm
the idle timing 2-4 deg - is adjusted by a screw on the linkage that rotates the trigger ( under the flywheel ) - it is for starting /idling and just in gear .
