confirming trim adjustment
battscrew
just to confirm - if hard pull to the right (Outboard)- adjust so the rear of the fin is slightly to the right (or counterclockwise).
captainbr
Re: confirming trim adjustment
You are correct. If the fin is to starboard, it will push the leg to port which will turn the boat to port, minimizing your tendency to turn to starboard.
