Computer Loses Time.....???
OBJ
Seems my computer clock loses time. Is it me or can it lose time? Don't know how it measures time....power cycles? Just seems strange.
Drowned Rat
Re: Computer Loses Time.....???
It can lose time especially if you rarely turn your computer off and on. Running programs that require lots of memory can also cause the clock to slow down. Restarting your computer should fix the problem. If it doesn't, try re-setting the CMOS internal clock. Press F2 during initial boot up to check and change time is needed.
ZmOz
Open up the clock and click on the internet time tab. Check the "automatically sync with an internet time server" box.
Plainsman
How old is the computer? Could be the BIOS battery.
OBJ
Thanks for the input guys. The machine is only a year old or so. I'll give the suggestions a shot.
Glad to know it wasn't "just me"....d:)
Plainsman
To set your computer clock go to Start>run and type
cmd >press enter
type or paste this in the dos prompt:
net time /setsntp:tick.usno.navy.mil
That will have your computer sync with the US Navy clock, which is the offical clock of the USA.
i386
I see that on some XP machines. Most are missing the Internet Time tab. Mine doesn't have it. Any idea what the diff is? XP Pro SP2 here.
i386
cmd >press enter
Yabut...
That one's a "restricted" server.
Instead pick a secondary server (or 3) that's geographically close to you. See Rules of Engagement
Plainsman
I use it at on my home network and at work.
ZmOz
I have no idea...I only noticed it was there a few months ago. I just reinstalled XP pro with all the updates, and it came with it.
Edit: Laptop with SP2 doesn't have it. Weird....
Plainsman
If your computer a member of a domain then this tab disappears. It gets its time from the PDC of the domain.
roscoe
ZmOz said:
roscoe said:
Exactly the kind of logic I would expect from a mac user.
Exactly the kind of problem a Mac user doesn't have to deal with. o:)
LMAO @ all.
It really makes you wonder.... even a $5 watch keeps time. 8)
waterinthefuel
Download a free program called atomic clock sync. It can be had at download.com and when run will automatically sync up your computers clock to the US atomic clock in Boulder colorado.
ZmOz
Mac CMOS batteries go bad just the same as every other computer, and their clocks are no more accurate than any other machine.
roscoe
You are assuming it is a battery or a clock problem.
Mine don't lose time.
But every pc I ever owned did lose time.
i386
Macs also have a battery and it's required for keeping time just like a PC. Also, on some Macs, the battery is required to boot the machine. So in some cases. No battery, no boot at all.
