Computer issue? ***update****
Boomyal
Every so often I click on a link, while on the internet, and my computer just shuts off and restarts. It then goes thru the disc check routine while restarting.<br /><br />This just started happening about a week ago and has occured 5 or 6 times. Any ideas as to what is going on???? I'm running XP Pro.
jsfinn
Re: Computer issue? ***update****
Hey Boom - <br /><br />Can you give an example of the link you're clicking on?
PierBridge
Sounds like a virus,trojan, spyware...<br /><br />Run adaware and spybot.
Boomyal
js, the latest one was a link to an online catalogue within a ski apparel website.<br /><br />ggoody, that's what I thought. I've run both plus TrendMicro anti virus and all is clean.
18rabbit
I'm thinking spyware...specifically a data miner.<br /><br />Download Adaware and run it. I run Adaware, Trend Mico's PC-cillin, and Spybot (also free). between the three everything gets caught ... that I know of.
Boomyal
Thanks all, I'm waiting to see if the problem is resolved. I had been using a now expired trial version of trendmicro anti virus. I just signed up for the whole program and ran their spyware program. It found one that Spybot did not. (websearch.a????)<br /><br />Prior to running it, I also had a usb icon, showing installed drives that were not installed. Now that indicator is gone. I'll play around on the net and see what happens. The shutdown/restart was becoming more frequent so if it's not fixed it will show quickly.
Boomyal
Originally posted by steve n carol:<br /> hey boom, any word from your detective?...sl
Negative SnC. The good news is that he has not come back asking for more money. The bad news is that I don't think this fits the old rule that 'no news is good news'.<br /><br />Monday will be the end of two weeks since I engaged him. I will give him a call if I don't hear from him first. I never really pressed for a timeline and I suspect that these things happen in little bits and pieces, if they're gonna happen at all.<br /><br />A little irony on the boat issue is that last week I just finished putting up the canopy roof (costco purchase) over the boat. The first time in it's 30 years its been under a roof....and now with no motor. Grrrrrrrrr!!
Boomyal
I apparently have this virus. "JAVA_BYTEVER.A". It is probably the cause of my problem.<br />Trendmicro has a special 'pattern file' to deal with it. So when the sun has quit shining (a rarity here in the PNW) I will study up on the issue and deal with it.
heyttown
Originally posted by rattana:<br /> I use this free virus protection, it works quite well www.grisoft.com
I use the same, very easy to use and install......Actually an IT tech recommended this anti virus software to me....Have yet to have a problem......."knocks on wood" ;)
Boomyal
I think my problem may have been due to a 'battle of the pop-up stoppers'. Only time will tell.<br /><br />I have been using Panicware Pop-up Stopper and I just discovered that IE 6.0 also now has a popup blocker. I think it is new and must have come on an MS update.<br /><br />Anyway, both were turned on. I just turned off the IE version and so far I've had no reboots when I either click on a new link or hit the 'back' button. This rebooting, while on the internet, was getting to be a real pain. I'm keeping my fingers crossed.
Dunaruna
Originally posted by Boomyal:<br /> I just discovered that IE 6.0 also now has a popup blocker.
How did you activate it? I can't find it.<br /><br />Aldo
Boomyal
With IE open, click on tools and IE's 'popup blocker' should be the second line. If you put your cursor on it, it displays the option to turn it on or off.
Boomyal
Nope, that was not the solution. I'm still having the shut down problem. Drat!!!
PierBridge
Sure sounds like vasser it might be time to wipe the drive and reinstall the OS.
BoatBuoy
I use IE popup stopper and Pop-Up Stopper with no problems. I think the IE stopper is in IE 6 SP2.
Boomyal
Originally posted by ggoody:<br /> Sure sounds like vasser it might be time to wipe the drive and reinstall the OS.
Thanks, ggoody! Just what I wanted to hear. :mad:
