Compression
waybill
What should the compression be on a 1967 15HP twin cylinder evinrude engine?
steelespike
Re: Compression
Minimum is usually considered to be 100 lbs.<br /> Should not vary more than 10% between cylinders.<br /> It will run with less but 100 is the minumum<br />recommended.
waybill
Re: Compression
Thanks for the information. I think I will buy a manual.
