Does anone have the factory compression numbers for a #15120 '53 15hp fastwin 'rude. A '57 QD-18 Johnson 10hp. and a Johnny 9.5. All bores look good with no scuffing, scratches, gouges, etc. My gauge is new and I get readings of 60-62/3 psi on ALL the cylinders from each motor. Either I have quite a coinincedence wherein each engine has eqaully worn rings/bores; readings that are in the acceptable range for each of the 3 engines; or a faulty test qauge. Any ideas appreciated and, I would really love to know where to find the factory specs. Have Selock & Clymer that are no help on compression ranges.
