compression
papasage
1974 70 hp 3 cylinder 120 lb top 150 on other 2 cranks run good at idle sluggis at wot. breaks up at mid rpms . new plugs all plugs firing strong . my suspishon is stater
rolmops
Re: compression
That hole that has 120 is trouble. Check it out. It may just be a stuck ring but that compression is way too low
boobie
Re: compression
30 psi between cyl's is to much. Pull the head and and see what you find.
JB
Re: compression
Before you tear into it do a decarb treatment then another compression test. Decarboning often loosens up stuck rings.
papasage
Re: compression
last time out the #1cylinder went out no spark replaced the power pack and coil and all 3 plugs started right upon muff . the top plug was black even around the thread . the engin has not ben run a full tank sinse i had it torn down for new rings and crank and all berrings .was running on all cylinders but the crank was bad .
boobie
Re: compression
Take it to the water and run it. That is the true test.
boobie
Re: compression
When it's acting up pull one plug wire at a time and see which cyl is not firing. AKA Cyl drop test.
phillnjack2
Ensign
Re: compression
good advice from above post.
you need to know whats firing properly and what is not.
if the engine has been rebuilt then dont expect the compression to be right untill its all bedded in properly.
tests tanks are fine for certain things, but nothing like a real river test to know a lot more about whats going on.
and please dont try it on your own, you need someone at the wheel at all times to be safe.
far too many people try it on there own and end up falling overboard with terrible outcomes.
phill......
