compression top 90lbs bottom 70lbs
JB
Re: compression top 90lbs bottom 70lbs
Over 90psi and within 10% of each other, Sandollar.<br /><br />Good luck.
rolmops
Hey Sandollar,there are some typos that need instant correction!!!
JB
HAHahaha!! :) <br /><br />Young folks worry about aging. Once you are there it no longer matters.
sandollar1978
I did not get that!! may be I'm a little to slow!! :D
ED21
Master Chief Petty Officer
Aging-Again. The only alternative to getting old is dead. I look forward to senior discounts. ;)
papasage
my 1979 has 125 lb. on each cylinder it was bord and oversized pistons over 10 years ago . hasent ben run in 7 years till this year .it should be like new. papasage
sandollar1978
Thats great, how much you think it would cost to have the cyclinder rebuilt?
papasage
without seeing the cylinders condition cant say how much it will cost .to pay a shop to do it you can buy a good used motor of that age. sell parts off that one on ebay. unless you can find one that they will fit.papasage
sandollar1978
Well I check the compression on the top cylinder I got 90lbs and on the bottom I got 70lbs so can you let me know if this is good our bad our thats why there no power thanks alot!!
Solittle
A 20 lb spread is more than is desirable but may be due to sticking rings so don't give up yet. Decarb the motor a couple of times and recheck the compression before doing anything more serious.
sandollar1978
Thanks SoLittle, but how do you decarb? thanks for your help...
wilde1j
Try doing a SEARCH (top of this page) on decarb.
moderator1
1978 Sandollar <br />Captain <br />Member # 34021 <br /><br /> posted November 24, 2003 08:29 PM <br />--------------------------------------------------------------------------------<br />Hi,well I have a 1979 55hp evinrude 2 cycile and it has very little power it starts great sounds good but it will only run about 15 to 20 mph so I check the compression and the top is 90lbs and the bottom is 70lbs so my questions is this ok for the year of the motor our is time to have it rebuilt our could it be the carb thats bad? well thanks for the help and happy holidays to every one!!! <br />--------------------------------------------------------------------------------<br />Posts: 38 | From: CA | Registered: Oct 2003 | IP: Logged <br /> <br />OutboardJim <br />Tackle Shop Admiral <br />Member # 18214 <br /><br /> posted November 24, 2003 10:37 PM <br />--------------------------------------------------------------------------------<br />Hey sandollar...happy Turkey Day to you to. <br /><br />Have you done a decarb lately? Yer a little better than 10% difference in compression. Do a decarb then do a warm compression test. See what pops up. Might just be a leaky head gasket.<br /><br />Keep us posted...thanks.<br /><br />--------------------<br />OBJ<br />*When all else fails...use the manual.<br /><br />--------------------------------------------------------------------------------<br />Posts: 2194 | From: Rayland, Ohio | Registered: Dec 2002 | IP: Logged <br /> <br />1978 Sandollar <br />Captain <br />Member # 34021 <br /><br /> posted November 24, 2003 10:45 PM <br />--------------------------------------------------------------------------------<br />Thanks OutBoard Jim! but how do you do decarb our what is that thanks agin. <br />--------------------------------------------------------------------------------<br />Posts: 38 | From: CA | Registered: Oct 2003 | IP: Logged <br /> <br />OutboardJim <br />Tackle Shop Admiral <br />Member # 18214 <br /><br /> posted November 24, 2003 11:02 PM <br />--------------------------------------------------------------------------------<br />Go to your local marine store and ask for a can of engine tuner. Tell them you want to decarb your engine. There are several brands, Bomby, Sea Foam, Merc has on also. But they all do the same thing. Get rid of built up carbon in the engine....<br /><br />Follow the directions on the can as different brands recommend different soak out times.<br /><br />Basically, hook the hose up to the engine, start and till engine reaches operating temp. Shoot the decarb into the carbs. You'll probably will have to idle up a little to keep the engine from stalling. Shoot the whole can into the carbs. Going to smoke like crazy but that's OK. When ya' get most of the can in, you let the engine stall. Follow directions on the can for soak time. Restart after soak and blow out losened carbon. Going to smoke some more. The do the compression test.<br /><br />--------------------<br />OBJ<br />*When all else fails...use the manual.<br /><br />--------------------------------------------------------------------------------<br />Posts: 2194 | From: Rayland, Ohio | Registered: Dec 2002 | IP: Logged <br /> <br />1978 Sandollar <br />Captain <br />Member # 34021 <br /><br /> posted November 24, 2003 11:08 PM <br />--------------------------------------------------------------------------------<br />Thanks for the reply OutBoardJim!! I don't have a manuel yet but do you know if I need to take the cover of the carbs? To spray the can of decarb. <br />--------------------------------------------------------------------------------<br />Posts: 38 | From: CA | Registered: Oct 2003 | IP: Logged <br /> <br />OutboardJim <br />Tackle Shop Admiral <br />Member # 18214 <br /><br /> posted November 24, 2003 11:19 PM <br />--------------------------------------------------------------------------------<br />Yeah sandollar...just remove the screws in front and it'll come right off.<br /><br />--------------------<br />OBJ<br />*When all else fails...use the manual.<br /><br />--------------------------------------------------------------------------------<br />Posts: 2194 | From: Rayland, Ohio | Registered: Dec 2002 | IP: Logged <br /> <br />1978 Sandollar <br />Captain <br />Member # 34021 <br /><br /> posted November 24, 2003 11:20 PM <br />--------------------------------------------------------------------------------<br />Thanks aging I'll get a can and try it and I post a reply thanks again... <br />--------------------------------------------------------------------------------<br />Posts: 38 | From: CA | Registered: Oct 2003 | IP: Logged <br /> <br />Mod2 <br />Moderator <br />Member # 25978 <br /><br /> posted November 25, 2003 12:31 AM <br />--------------------------------------------------------------------------------<br />Sandollar....I noticed that this post is a repeat of a previous post by you. All you need to do is answer yourself and it will bump back to the top. Just click on "post a reply" and put a "^" in the answer area. This will keep your post together. Thanks. <br />--------------------------------------------------------------------------------<br />Posts: 150 | Registered: Jun 2003 | IP:
moderator1
Sandollar, Your two posts have been combined.
sandollar1978
Sorry about the double reply!! But thanks for fixing it. Happy Thanks Giving!! :D
sandollar1978
Hello every one great thanks giving! Well I decarb my 1979 evinrude 55hp and I'm still getting 90lbs on top cylinder and bottom cylinder 70lbs I decarb for about 30mints I done almost the hole can of mercury engine tune I I could not find the seofoum should I buy a nother can and decarb for over night? well thanks...
