compression too high?
medic2051
compression readings on johnson 50esl75 were 150, 152. Seems kind of high. Is that possible?
JB
Re: compression too high?
Oh, yes. That is possible and it does not indicate any problem.<br /><br />There are too many variations in guages and in methods to set a psi and say that "this is what it should be".<br /><br />The important number is the difference among cylinders.<br /><br />I would say that you have a mechanically excellent Johnny there. :)
rodbolt
the 72 50 hp models will read about 180, its the way the heads were designed.
