Compression Testing - Too high?
USS Neversail
83 Evinrude 50 hp - left out for 4 yrs. - cleaning it up now. <br /><br />The carbs are now clean. Not as much gunk as I thought. :D <br /><br />Did a compression test 155/160 (top/bottom cylinder). That seemed a little high. I don't have any #'s to let me know if that is good or bad. Any idea's out there in expert land? <br /><br />I appreciate it.<br /><br />Jason
norman158
Re: Compression Testing - Too high?
sounds real good to me it may drop some when you run it some but i wouldnt worry about those numbers
G DANE
My 40 HP 1988 sitting for 5 yrs had 148/150 i guess this is the original comp. figures.<br /><br />It needs a fully charged battery !<br /><br />Good luck
USS Neversail
I just put a brand new battery on it, so got that part covered. <br /><br />Any suggestions on where to look for the factory compression #'s?<br /><br />Thanks for the input either way. :D <br /><br />Jason
Mikael-Block
Hi<br />I wouldn't worry so much if it is 130 or 150<br />as long they are within 10%. Yours ar perfekt.<br /><br />If you whant to compare with factory messure, you have to have a precise instrument, that have been calibrated. I dont think you can compare messurement form 2 diffrent instruments.<br /><br />mikael
clanton
Jonson/Evinrude did not give compression specs in service manual.
Dhadley
Those numbers are good and not unusual given the port timing configuration in that motor.<br /><br />Good luck!
USS Neversail
Right on, then! Sounds like all is good. Thanks to all who posted.<br />I appreciate your help.<br /><br />dhadley - what is port timing configuration? <br /><br />THANKS, All!<br /><br />Jason
