Compression Testing Procedure
timfromfc
I just bought a compression tester and the instructions say to get the engine to operating temperature before using. How much will it affect the results if done cold? I have ear muffs but can never get water to spray out and I get nervous about keeping it running too long. I don't really want to do it at the lake either. Does anyone have any advice?
eurolarva
Re: Compression Testing Procedure
Just let it run a couple of minutes on the muffs. Warm is better then nothing. The difference between the cylinders is more important than the actual numbers. Your numbers should be over 100 and each cylinder should be less then 10 digits apart. When testing make sure you have all the plugs pulled and connected to the wires with the plug threads or tips grounded. For safety try and keep the spark as far away from the open cylinders as possible. Wouldnt hurt to have a fire extinguisher around for safety. Dont worry you wont start a fire. It is just for safety.
WillyBWright
Doing it warm gives you the most meaningful and accurate compression readings. There won't be too much or too little oil that can throw the readings. Plus the parts are mated best at operating temperature.<br /><br />I do it cold for customers unless I want to compare readings from warm and cold. Time is money and warming up takes time. Cold readings still give you good enough information. If time isn't an issue, do it warm.<br /><br />The extinguisher is in case the motor has gas in the cylinders which can spray out and ignite from a sparkplug. It's rare but certainly possible.<br /><br />I take it your motor doesn't have a telltale. The water won't come out of the holes on the back of the motor when you're on muffs. It needs exhaust back pressure from being in the water. You can probably install a telltale. Many Chryslers and Forces have a plugged 1/8 pipe hole in the head. Screw a fitting in there and route some speedometer or aquarium hose out of a rear corner thru a hole you drill in the pan. Definately a worthwhile upgrade.
timfromfc
Thanks for your input!!! I always have a fire extinguisher in the garage anyway. Good idea to keep it handy.
JamesGY
Why not just turn on the kill switch so that you get no flame?
