Re: Compression Test Results??
They are within roughly 10% of each other so are ok. If you haven't decarbed the engine you might try that and then retest. The lower cylinders may come up some. You might also retest the 115 cylinder. If the engine was cold you might try retesting all cylinders with the engine warm. You would then have a very complete set of numbers. However, as it is, the numbers are ok.
