Compression test on 1973 mercury thunderbolt 850
Kmyers
I bought a 1973 mercury thunderbolt 850 and that has been sitting for about 20 years in a barn. I did a compression test on it cold and it shows 135 cyl 1 142 cyl 2 120 cyl 3 145 cyl 4 is the reading on 3 going to give me problems. I am trying to decide how much to put into it I got a pretty good deal on boat and motor was a bonus. So far I know I need an engine harness at least any help is greatly appreciated.
M
Maxz695
Guest
Re: Compression test on 1973 mercury thunderbolt 850
If you post the serial number of the engine someone can guide you to the part number for the harness and you can search ebay for it under the part number. I doubt highly it is not an obsolete part on most new parts sites.
Kmyers
Thanks maxz695 I have found the harness on a couple of sites and I will check eBay for the part number also but I want to make sure the motor is worth putting some money into.
JB
Don't worry about the compression until after you have gotten her running. Then do a decarb and a new test.
sutor623
Do you need internal or external wire harness? I haven't looked through these but possibly one will work for you? At least it will give you an idea of price on these older harnesses. How does the lower unit feel? If I were you I would yank it loose and see if it even comes loose, then check if it shifts. So many headaches could pop up on these motors. When I got mine up and running, it was literally part after part until I got a reliable motor out of her. Started with lower unit rebuild, then starter, then trigger plate, plug wires, carbs, fuel lines, wire harness, stator re-wire, yada yada. If I had known I may have taken that $4-500 and just put it toward a newer motor. Dont get me wrong, now that shes runnin Im happy, but boy what a frustrating journey......
http://store.oldmercs.com/SearchResults.asp?Search=wire+harness
