When testing with compression gauge on small (15HP or less) 2 cylinder older OMC's with Magneto Ignition do(es) the Spark Plug Wire(s) need to be grounded to avoid damaging the Coil/other? If I have only 1 Compression Gauge, what is the best method for Compression Testing (other Spark Plug installed but with Spark Plug Wire disconnected vs.disconnected from Spark Plug but grounded, etc)?
Also, what is best Compression Testing method on the newer Electronic Ignition (around 1977 etc) outboards?
