Compression Test--45 , 45 and 45 on 85HP Force URGENT
CraigO
I am getting ready to purchase on line a used 85HP Force outboard to replace the outboard on my boat.<br /><br />I had the person do a compression check for me and he got values of 45, 45 and 45. I know the values should be around 125 to 130 per cyl. <br /><br />QUESTION: Is his values valid as he was turning the flywheel by hand (actually with a wrench on the flywheel nut)??<br /><br />Do you not get the proper values unless you hook starter up to a battery and turn over?<br /><br />and if so is the 45,45 45 a good sign as it is showing balance on on 3 cyl?<br /><br />Also, supposedly the only thing wrong this outboard is no spark? I hope this should be no problem as it should be real easy to take the CDI? sending units off of my old engine---this should be simple right???? I think it is close to the same year as my existing 1985 85 HP Force. Can one tell the year by the serial number?<br /><br />Please help--I may be making the purchase today
wilde1j
Re: Compression Test--45 , 45 and 45 on 85HP Force URGENT
No, Yes, Yes (but not valid)<br />?, ?, Yes
Jango
The proper way to check compression is:<br />1. remove ALL plugs<br />2. Open throttle to WOT (OUT OF GEAR)<br />3. Check each cyc by cranking with Starter - be sure each plug wire is grounded to Block to avoid Elect. damage.<br /> Readings should be within 10% of each other and at least 120lbs for that motor.<br /> If you are going to change Power Packs and Coils, Be sure you use the SAME color. If they are currently BLUE, change to New Blue not Black.
steelespike
Force is an orphan with no factory parts support.<br />Marginal performance and reliability.<br /> Why bother.
Hooty
URGENT ??<br /><br />c/6<br /><br />Hooty
