Re: Compression Release Valve 1957 35 hp
There's not much you can tell by looking at the top of the pistons. All you really can see is the condition of the bore, and from that make some assumptions about the condition of the pistons and rings.<br />Scratches along the direction of the piston are bad - the more and deeper they are, the worse. You can get an idea for bore wear by feeling for a ridge near the top of the piston's travel or more accurately by measuring the bore. You will not be able to gauge ring wear (except to assume it's proportional to the bore wear) without removing them and measuring their end-gaps. <br />My '65 33hp surprised me. It had apparantly good compression (100 - 105 psi by my guage) but when I disassembled the engine I found the bores & pistons badly worn from use rather than abuse, and the rings were nearly completely worn out. The end-gaps could be measured with a ruler rather than a feeler guage. There were no gouges in the bore wall and little evidence of overheating on the pistons. It just goes to show that a _very_ thoroughly used 'Big Twin' will still produce good compression.<br />It seems to me that the most common cause of bad compression on these engines besides abuse like overheating or lack of oil, is simply caused by carbon or coke sticking the rings in their lands. Since they no longer press against the cylinder walls, compression is lost. The simple solution to that is to decarb the engine regularly. Occasionally this will cause a great gain in compression as a ring frees.<br />I have yet to see a 'Big Twin' head that wasn't a little warped (few thousandths), so I think that's par for the course. Go over the cooling system - particulairly the water pump - as that's a frequent cause of blown head gaskets. Like Chinewalker said, they're not exactly unheard of anyway. Especially with warped heads and poorly torqued bolts.
