Could someone please advise what the correct compression would be on 1992 Outboards (Yam, 250). I'm told it tested out at between 95 and 103 on all six cylinders, with none below 95. Thanks.
Compression is in direct relation to cranking speed. If the compression is within 12% from the highest to the lowest, no problem. I've also seen compression gauges differ as much as 30 psi.
