I've a 1995 Kawasaki Zxi 750 that's been driving me nuts. The engine was overhauled, the carb completely gone through, and general touch-up here and there. The work was partially done by me and partially by the previous owner. The problem is that it won't start. I've checked the fuel system inside and out and while I can't be certain it's not the problem, nothing obvious jumps out at me.
I checked the compression and it's reading 125 psi on both cylinders. The owners manual says 185 psi and the service manual says 125-193 psi. I'm guessing since I can't start it, the low compression would be normal? Does the compression then increase once there is cooling water in the exhaust?
I need to figure out where my problem lies and I don't know if I should continue to troubleshoot the fuel system (which is where I suspect the problem lies) or with the engine itself. I've decent spark and if I pour a few drops of fuel down the carb throat it starts for a second.
