four cylinder 2003 Honda 90hp BBBL 4501214   did a compression test and had 115 cyl #1 , 110 cyl#2 , 70 cyl #3 , 130cyl #4  scared me to death.
Op's I forgot to open the carb throttles when I did the above test.
second test with carbs open..... 185 cyl #1, 182 cyl #2 , 182 cyl #3 , 185 cyl #4..... OK now I'm confused, why such random pressures with carbs closed and even compression with carbs open, and does this indicate a problem.
