Compression problem or nothing to worry about?
Redneckhick
Hi all
I have a 1976 Mercury 850 that I'm thinking about finding a pontoon boat to put it on. I did a compression test today #1 had 102 pounds and the other three had 110 on the nose. The water cover gasket also leaks around #1 but none of the others. I'm thinking the motor has been ran hot at some point over the years and #1 got the hottest. Do you guys think it is enough to worry about on a motor this old? Thanks
PHE
Re: Compression problem or nothing to worry about?
That's within 10%, but I would decarb the motor and see if #1 comes back up. If you look in the FAQ there is a good procedure. Carbon causes the rings to stick, and eventually will push the rings out enough to break them causing serious damage.
Redneckhick
Thanks just went and got some Seafoam this afternoon.
