compression on 94 40hp 4 cyl merc
ran
what is the compression for a 1994 merc 40 hp and where did you find this info. thanks in advance.
mnmfors
Re: compression on 94 40hp 4 cyl merc
I own a 90hp merc. I am pretty sure it would be at around 100-150lbs. per cyl. and more importantly the lbs per cyl. should be fairly close.
ahm
I own a 1989 80hp 3 cyl merc and its compression is 110 psi when cold. I am told it would be higher when warm.
