A spark plug "steamed cleaned" led me to believe that my bogging down problems were related to water entering my top right cylinder. Upon removing the head gasket there was an area that looked scored-<br />also some score marks on the top of the piston head- almost if the spark was arching (did have an electrical problem with a dual battery system last year). Compression on 3 of the 4 cylinders ran approx. 135-140psi. The "steamed" cylinder only showed 60 psi but immediately jumped to 80 psi<br />as soon as we replaced the gasket. These readings<br />were taken with the engine cold- something I now realize was done wrong (live and learn by reading some great stuff in this forum)<br />Anyway to make a long story short (or shorter)-<br />the boat now literally runs fantastic. Reaches<br />about 6200 rpms at WOT. Somewhat baffled because<br />there is such a large difference in compression in that one cylinder but the engine idles fine and<br />and is smooth. The engine does have a very slight <br />"clanking" noise when idling. Is this normal for a 2 cycle engine? What does crossflow mean. Is this engine a crossflow? What do you pros out there gather about this compression thing? What is the "normal" compression and max WOT for an 85 140HP engine.Just trying to keep what I have in the best possible condition. I do own a Clymers manual but I'm more of a visual person and I don't understand <br />alot what is said in the book. Thank you to all who have been so informative.
