Re: Compression on 135 hp Evinrude
Compression #'s have nothing to do with the HP of the motor, although as you lose compression you will lose hp and performance, as was said, but it does not mean that high HP has high compression and vice versa. I have an old '75 70hp that has 130psi of compression on all 3 cyl. I also have a 200hp with 100psi on all 6cyl and has been like that since the factory. As long as the compression is equal or with 10%, your fine. Decarb it a couple of times and you may get a little bit more compression on it.
