Re: compression numbers?
You have to remember that compression numbers are a mere indicator of engine condition and not a one size fits all thing. With that said, if those compression numbers are all within a 10 to 15% window of all cylinders, then for the most part the engine will run. Higher numbers are better of course, but not the only determining factor if an engine is good or bad. So let the numbers between all cylinders be your guide and not the good or bad motor decision issue... I've heard folks with 85 PSI and even lower numbers run all day long without problems...
