Compression for 1988 140 Evinrude
havinfun
motor has been rebuilt, would like to know what the compression numbers should be, also, should I check with engine warm or cold?
Dhadley
Re: Compression for 1988 140 Evinrude
Welcome!<br /><br />You can check it warm or cold, just recheck the same way with the same gauge each time. Do both and keep the records. The numbers should be within 15 lbs. Actual numbers will depend on several things like which heads you have.<br /><br />Good luck!
havinfun
thanks for the quick response, greg
