COMPRESSION CHECK
rickdb1boat
Re: COMPRESSION CHECK
ARIZONABASSMAN,<br /><br />Warm up engine,<br />remove all plugs,<br />Ground all plug wires,<br />connect compression Gauge'<br />Hold throttle wide open,<br />Crank at least 4 times for proper reading!<br />Try to crank each Cylinder the same amount of rev's!
KEITH VIERE
IS A COMPRESSIIN GAUGE RATED IN P.S.I. IF SO WHAT IS THE NUMBER OF P.S.I. IM LOOKING FOR.
rickdb1boat
Yes, PSI. At least 100PSI on all Cylinders and within 10 percent reading of each other.<br /><br />EDIT: The most important thing is that they are all close together in readings! 100-95-100-100 Something like that is OK! (Not to say that is what you have or will get)
KEITH VIERE
THANKS RICK, ONE MORE QUESTION FOR IF I COULD? WICH MOTOR WOULD BE MORE RELIABLE. 1998 JOHNSON FICHT 150HP OR 1999 225 JOHNSON H.O. STRAIGHT CARB . I'M IN A TOSS UP.
rickdb1boat
Have heard bad things about that year FICHT. I would stay away from it, unless you know it's backround real well! Of the two, I would go with the 1999 225!
rickdb1boat
You might do a search on : FICHT, at the top of the page for more opinions!
Sand Bass
Arizona, I would stay away from the 1998 FICHT. That motor has problems. I have an Evinrude 225 (carbed) that has performed well for me. What are the compression readings on the 225?
KEITH VIERE
THANKS RICK AND SAND.I'LL GET A COMPRESSION READING ON 225 SATERDAY MORNING . IF IT IS GOOD I'LL TAKE THE 20 FOOT JAVELIN HOME. THE MOTOR ALSO HAS THE BULLIT LOWWER UNIT. SHOULD BE VERY FAST.IT WILL BE A BIG CHANGE FROM 18 FOOT BASS TRACKER.I GOT ON A BASS FORUM FOUND ALOT OF BAD ON THE 98 FICHT. LOOKED UP THE JOHNSON 225 HO AND SEEN NOTHING BUT GOOD. I GUESS I WILL PUT UP WITH LITTLE SMOKE BUT WILL NOT SACRIFICE PERFORMANCE.
