Re: compression check should be around?
Anything above 90psi is considered good Joe. More important is how the compression readings compare to each other. Generally ya' want the cylinders within 10 to 15% of each other. So you could have, for example, 85 and 90 psi but they are well with in specs.<br /><br />If the compression seems a little low, do a decarb and retest.<br /><br />Let us know what ya' find.
