Hi to all, and thanks for all the info I've learned in the past.<br /> I'm trying to do a compression check on an 84 merc 35 hp s/n 62490024. I've done a check on the top cylinder, but was wondring what the trick was to getting the compression gauge screwed in to the bottom cyl. The lower cowl blocks direct acess to the lower plug hole. Is there an adapter avalible? Ideas? ...thanks
