How is the best way to check compression in a 1969 Johnson 85 Hydroelectric Drive V4 that is stuck in gear. I believe it is a dead solenoid but don't want to bother if the compression is bad. My thought was to take the bottom end off. Is there a better way? If the solenoid is dead is there no way to manually get it out of forward to neutral so it will spin? I don't see many of these solenoids on the market at all. If one or both are bad can they be found. Amplifier looks cracked as well, Yea! I've heard that 120-125 PSI is good. At what point is it not worth keeping? below 100PSI?
Thank you for any assistance received.
Going on a 69 Boston Whaler 16'
