Pokertrampp
- Sep 17, 2009
- 279
1988 Johnson 120.
I have been having an issue with this motor for some time and I think I may have found the problem, but would like another opinion.
I checked the compression and I have 100+ on all cylinders so I figured I was ok. The motor continued to have a mis so I checked it again same readings.
I checked it a third time just for piece of mind and one cylinder was now down to 70 psi, so I checked yet again and now down to 50 psi, checked again now back up over 100+ psi.
I pulled the head gasket and all I see is one very small spot and I think the ring on the gasket should be a little thicker but I am not sure.
Has anyone ever heard or had a headgasket do that or is this from something else. Thanks Again
