I have recently measured the compression on my outboard. The values were all 89-90 psi except for 1 cyl. , this was 78. <br />Question : Is this 1 cylinder supposed to be low? I have heard others talk about a new engine having 1 low compression cyl.<br />If this is not normal , is it too far out of the range ? The motor runs well.<br /><br />I have run de-carb in the engine as per the directions(Yamaha de-carb) and there has been no change. Should I fiil the cylinder with the de-carb and let it sit for a while?<br /><br />The reason I have checked the compression is that I have lossed several hundred rpms at wot. I'm now thinking that the barnacles on my motor bracket may be the cause. The compression is the same as when the boat achived the 5500 rpms a month ago.<br /><br />Thanks for all the help . This board is great and I hope the impatient visitors will soon realize this.<br />God Bless America and all it's survivors!!
