compress check?
tgodiver
Yamaha 225 HP 1999 SWSII. How do I going about checking the compression? Can I do it with muffs on or do I need to put it in a test tank?<br /><br />Do I need let the engine warm up before I test it as well?<br /><br />Thanks
Forktail
Ensign
Re: compress check?
Oh boy.<br /><br />JB just closed a good thread on this for the sake of some being confused....whoever they were.<br /><br />I do my compression tests warm. This way the viscous oil has circulated throughout the cylinder wall/rings providing a more realistic seal, and the engine's materials are expanded. Compression will generally rise with a warm engine. This should help diagnose any cracked pistons, cracked cylinder walls, broken rings, etc that have trouble building compression when heated. These type of failures don't always show enough % differential between cylinders when cold checked to make a proper diagnosis.<br /><br />Most manufacturer's compression numbers (that you compare to) will be measured warm, and most procedures to check compression will specify doing the check warm. <br /><br />There is also a "leak down" test that you can perform to isolate the problem further. This is done by pressurizing the cylinder or crankcase to find leaks.
ob
Re: compress check?
tgodiver, Warming engine up on muffs is fine.No need for test tank as you will simply be cranking engine over with starter to obtain readings.Much easier to perform if you'll obtain a remote start button and jump from large 12v cable on solenoid to ignition terminal on same.Most auto part stores will have a hand held one for fairly cheap.
tgodiver
Re: compress check?
Do you take the reading with the engine running by replacing one plug with the compress gauge , or just crank it to turn over and diable the ignition by taking all the plugs out?
