Compounding question.
f_inscreenname
I have a (interflux) painted fiberglass boat with a couple stains. I am going to use rubbing compound before I wax. After reading the can it says " rub on and wipe off" nothing about letting it dry first. Do I let it dry? Would you wipe or buff it off? Would use a buffer to put it on? Give me your best tips before I screw it up. <br /> Already did the search thing and couldn't find what I am looking for.
codyandamber
Re: Compounding question.
I say just hand buff it on and let it dry a bit. Then wipe it. It will come off easier. Of course, that is the easy way. You are really suppost to just buff and buff and buff until it goes away. The good ol' Navy taught me that. They never taught me to use a buffer though, so I'll leave that to someone else.
Ghost
Compounding is done by constantly rubbing the compound in either by hand or machine. You never let it dry, just rub until it is gone.<br />Are you sure you want to compound a painted boat?<br />Try 3m finness polish it is less harsh and gives good results.
Ya, Rubbing Compound is sort of like Sandpaper......Gob it on, Rub till your spot is gone, Then Wipe Off...
Mikedg
I would not use rubbing compound on a painted boat. There are special products for cleaning and shining Interlux paints. Regular products for fiberglass will ruin the finish.<br /><br />Here's a link to their site for more information: http://www.yachtpaint.com/usa/
MoRambler
Before I'd use rubbing compound, I'd try using polishing compound and thin it with water. Many body shop guys do this. It is MUCH less abrasive, and if it gets the stain out, all the better. I would use rubbing compound as the last resort.
