Re: Composite Props
Jeff, composite breaks pretty easy, as you can see from other posts, but that may be a good thing, if you are fishing Fork Toledo, or Rayburn(the stumps). It is better to break a prop than a prop shaft........ However, I am on Texoma with very little structure and a lot of sand......My composite prop would shear too often when hitting sand(sandy lakes have more shallows and sand bars everywhere). I switched to stainless with a hub, and it has lasted for years......I have hit sand several times with no damage. I chose the hubbed version just in case I hit a rock or structure, the hub will blow....and now they make the two piece hard plastic hub you can change on the shore.......anyway, look at where you will be spending most of your time on the water and choose wisely...
