Pretty much. Monster is known as one of the better cables with product value in mind. In other words, its better than an el-cheapo component cable, and only over-priced, as opposed to unbelievably over-priced. I think Monster may be using coax with a stranded center conductor (makes for a more flexible cable). You should look at your cable and see. If it is coax it has (a) an insulator on the outside, (b) then aluminum foil and/or braided wire shielding, (c) then foam dielectric, (d) and then the center conductor (often a single, solid copper wire but can be stranded). You should get RCA phono/coax connectors sized correctly for the Monster cable. They will crimp on. If your cable isnt coax, you may have to do some soldering.<br /><br />You might also try calling Monsters customer support, you might talk them into sending you 1 or 3 connectors. 1 (877) 800-8989.Originally posted by BassCat73:<br /> ... Is it as simple as sticking the wire in the new connect and crimping it down? ...
For interconnect cables (audio and/or video, analog or digital):<br /><br />Beldin 1694A solid conductor coax<br />Beldin 1505F stranded conductor coax<br /><br />Should be available wherever tools and connectors are sold. The 1694 coax is the standard cable used in the broadcast industry.Originally posted by CalicoKid:<br /> ... There is a comparative cable with a braided flexible center conductor but I can't remember the # of it off hand because I use just the solid for my in-wall installations.
