So I bought this boat with a cracked block and cracked heads. The cracked block is 5.7L Merc 0K001527. I had another 350 longblock sitting here so I took it to the machine shop, had it bored .060, grind and balanced the crank, new cam bearings, new main bearings, new rod bearings, new .060 rings, new .060 over pistons, and new brass freeze plugs. This longblock I had is about 10-12 years older than the cracked one. I switched the intake manifolds to one with the correct angle holes for the older style heads and then put a model 1409 edelbrock carb on it along with the necessary quadrajet to square bore adapter plate. Lastly I changed the oil pan, flywheel, coupler, and starter to match the two piece rear main seal vs the prior one piece that was on the cracked one. All of the other external were transfered over such as the thunderbolt V dist, oil sensor, alt, wiring harness, and exhaust manifolds.
Well the darn thing wont start. It wanted to very briefly but I didn't let it because I noticed a small fuel leak in the connection coming up from the mechanical fuel pump. Fixed the issue and now it won't even pop a little. It kind of seems like this carb is drowning it out. I did btw place the distributor in base timing mode by connecting the pur/wh wire toa good ground. I'm starting to get really nervous thinking that for some reason this whole set up is not gonna work now that I have almost 2k into it.
Please help if you can.
Thanks.
Thanks.
