Darkhorse1201
- Oct 17, 2005
- 108
I have a 1992 Sunbird with a 4.3 OMC motor. Runs great til the other day - I switched on the blower motor and the motor did not work and all the guages flew to max position. I turned off blower switch and all gauges return to normal. The same applies to any dash switch or even radio. Motor will not trun over unless I put a screw driver across solinoid terminal. When I disconnect battery and put multi meter on it ( neg on ground) and touch positve test lead to any positive terminal on motor (using ihm metter0 I get a circuit. I have check every circuit and cannot find any chafed or grounded positive wire but obviously there is power going thru the ground circuit but noy enough to trip a fuse or fry a wire. Any ideas on where to look for this puzziling problem? Thank
