Compatability BW 1975 & 1982 70 HP Johnson
bigwhitebear88
I have a 1975 70HP Johnson Outboard which runs OK but need some TLC. I have located a 1982 70HP which is not running but I could possible use for parts. Can anyone help me as to whether or not here are enough similarities between these motors to make getting the 1982 worthwhile, or would I just be wasting my money?
Thanks for any help
seahorse5
Re: Compatability BW 1975 & 1982 70 HP Johnson
Ignition systems are not interchangeable between those years.
bigwhitebear88
Thanks Seahorse
The ignition on my '75 is OK I was thinking more on the mechanicals, Starter motor, carby's, pistons etc, power tilt/trim unit gearbox etc
Any thoughts?
Daviet
Look at the parts breakdowns of each engine and compare part numbers.
bigwhitebear88
I checked the link but it doesn't say whether the tilt/trim assembly from the "82 will fit the '75. Can anybody confirm if they are compatable.
Thanks
