Could someone give a recommendation for a compression and spark testers for 1996 50hp 4 stroke merc?
J Jesse75 Cadet Joined Jul 11, 2015 Messages 11 Jul 19, 2015 #1 Could someone give a recommendation for a compression and spark testers for 1996 50hp 4 stroke merc?
gm280 Supreme Mariner Joined Jun 26, 2011 Messages 14,605 Jul 19, 2015 #2 Jesse75 said: Could someone give a recommendation for a compression and spark testers for 1996 50hp 4 stroke merc? Click to expand... Most any auto parts store carries both those things and shouldn't be hard to come by. The spark tester looks like this; There are available and really cheap as well. And a typical compression tester looks like this: Again available in most auto parts stores fairly cheap as well... Hope that helps you out... JMHO!
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Jul 19, 2015 #3 AutoZone has loaner compression testers. You buy it and return for full value when you're done with it. AZ also has a similar spark tester for less than 10 bucks.
