Commander 302 Won't Fire
Cgoshia
I was out on the boat last weekend and just go up to the boat today, and it won't start. I changed out the ignition coil, ballast resistor and I know for fact that these were wired up correctly because the engine fired since but I really haven't had it running since those part were swapped, I tried hitting the starter with a hammer and I am still not getting it to run. I can hear
Don S
Re: Commander 302 Won't Fire
Do you have spark?
If not, did you replace the points and condenser? That's the cause of no spark about 99% of the time.
Cgoshia
Go a new starter and put a new solenoid on there and the boat would crank when I'd 'hot wire' it but not at the turn of a key. Any ideas?
Cgoshia
Thank you Don for that post it helped me diagnose all my issues this weekend. I have new problem though not covered in that thread. I ran for about an hour this weekend and lost all power to the motor. I dropped anchor to see if a wire had come loose or something. Everything looked fine till I looked at the ballast resistor and the thing cracked in half. It's a brand new one and I'm not sure if it's defective or if there may be a bigger issue.
