Let me start off by saying the engine is 140hp-1980, on a 17' ski boat. Used the boat last week,probably put 10 hours on it skiing,tubing etc. total. My question is first thing in the morning I would start up the motor using the "cold start method", (squeezing the primer bulb, turning the key to on postion, pushing it in 8 times to activate the choke solenoid,lifting the cold start lever all the way up crank it over,engine starts right up no problem what so ever) Take the grand kids skiing and tubing everything is still good engine idles at 800rpm,no problem-problem occurs when I shut the engine down,then try to start it after a few minutes of down it won't start... If I lift the "cold start lever" just a little ways up 1" or so then turn the key on the engine starts up as if nothing ever happened. Any suggestions? or thoughts?
Bailey
Bailey
