strandedpontoon
- Aug 1, 2004
- 4
I bought a pontoon with a 1987 90hp Johnson outboard motor on it. The motor seems to be really cold natured. It takes several times before it will crank and then once cranked, I have to let it idle at high rpms (then slowly decreasing rpms, let it run, then decrease, let it run, before finally letting it idle at it's normal rpm -taking 20 minutes for this process). Then I can put it in gear, of course then it sometimes cuts off. I'm thinking of changing the spark plugs and the fuel filter. Could this be a carburetor problem?
