Re: Cold Misfire
While inspecting switch box I found an exposed wire from switch box to trigger assembly and an exposed wire from switch box to one of the coils. I replaced trigger assembly, stator (while I was at it) and wire to coil. Test ran it in the bay and it did the same thing, seems to run on 2 cylinders at WOT then after it warms up the other one kicks in. Compression on all cylinders is good. I'm waiting for a new switch box hopefully it will do.
