coking??
dmurray
I have been breaking in a 1988 j110 hp and I noticed the top stbd plug is sooted up and the other three look tan. I had an earlier post that referred to coking. Is this something a driveway mechanic can do?? I have got this far and I do not want to have to rebuild.
Joe Reeves
Re: coking??
Coking is a white waxy like substance build up, A thick build up which is unlike any carbon build up one would ever see. Coking can reach a thickness of 1" easily in a rather short span of time.<br /><br />The only cause of coking that I have ever come across was that a engine would be over pitched. This results in having the carburetor butterflies wide open at full throttle, the spark advance set to full, but the engine would be unable to reach the proper rpms. This in turn prevents the engine from breathing properly, the exhaust can not escape normally, with the final result being.... coking.<br /><br />Your spark plugs should be Champion QL77JC4 plugs, gapped at .040 . Compression should be 100+ psi and even on all cylinders. Spark, w/plugs removed should jump a 7/16" gap with a strong wide blue lightning like flame.... a real SNAP!<br /><br />Soot indicates a weak spark. Check the continuity of the coil(s)... plug terminal to ground wire, plug terminal to primary wire. You should obtain a reading on both.
dmurray
Re: coking??
Thanks for the response Joe. I must have soot, because it was black and crusted. I am using NGK BR7HS @ .030. I will change this week, though this is what the shop gave me. I will check the continuity tomorrow (It is supposed to freeze for the first time in years tonight)(I wonder if I am supposed to drain water??) Florida is different, huh??) Thanks again
