I also see some real heat was applied to the right point assembly. The discoloration is obvious. I don't know your engine or can see the crank lobe(s), but I don't think both points are to open at the same time unless I don't understand that setup. Usually one point opens and the second one opens 180 degrees later in the revolution. After installing the new turn up kit, set both points to the 0.020" setting and see how that works. Some times that point setting is stamped somewhere on the metal casting in the ignition area. I would suggest checking the condensers (capacitors), but with new parts, it is a moot point now. However, do check both spark coils to make sure they are not shorted or open. Use a volt ohm meter set to the resistance scale and verify the primary and secondary resistances according to the owners manual specifications. If they read in the proper range, you should have a working engine after the turn up kit is installed and set.
One other issue, when you install the new parts, be very carful that no wires are laying to where they can be pinched, cut or brushed by any moving part. It will run for a short time until the wire rubs through and shorts. Just a heads up. JMHO!
