Coil pack specs?
bcsukas
I have a Evinrude E120TLCEM and was wanting to find the specs on the coil packs? I just ordered a manual, but I was wanting to put use volt meter and test resistance in packs to see if maybe this was cause of my issue. Don't know if this would tell me anything or not, and if it would does it need to be done once packs get hot? I've had issues with the coil over packs in my F150 and I know they don't act up until hot. See my signature to get boat details. Issue is the boat will run fine for 10-20min(lake is small) at 3/4/full power. Shut off and let sit for 10min, motor fires back up no problem, but when I go for throttle, no power? Motor idles fine and not sputtering or cutting out. Attached below is a pic of the plugs, these were brand new, notice the right one looks like it hasn't sparked much?
Thanks for the help
DC20
Re: Coil pack specs?
Try cdielectronics.com for info.
