Re: Coil back tab catching on flywheel - can I file it down?l
Hi Rmsari. Assuming the coils are the right part number, they should be fine do not file them down. It's pretty common to have some alignment issues when putting new coils on. Try loosening the screws that hold coils in place a little and pinching both coils in towards the center of the magneto plate. Hold them pinched with one hand and tighten them back down with the other. They do make a special ring to align them, but you don't really need it. Once you're readjusted them put the flywheel back on and spin it a few times by hand with the spark plugs removed. If you feel any rubbing, try readjusting the coils again. Don't worry, they'll fit under there you'll just have to fiddle with them a bit.
