hi guys, i just recieved a remanufactured cobra lower unit, purchased through IBoats, and the end fitting for the shift shaft was not supplied, i assume i have to use my old one, does anybody know how to separate this fitting from the shift shaft. the new shaft is not threaded , just ground to a taper at the top. let me add ,im very impressed with the workmanship on this unit so far.ill let you know how it performs ,thanx mickey1
