Cobra Outdrive Propeller Compatability
sailforth
Does anyone know if a prop from a king cobra outdrive will fit a standard cobra outdrive. Are the splines and shaft OD the same? Any help is appreciated. :confused:
CCrew
Re: Cobra Outdrive Propeller Compatability
Depends on which "standard Cobra Outdrive". The early 4cyl ones have a different prop shaft diameter than the later ones and the V6-V8's. <br /><br />-Roger
sailforth
I have a 1988 cobra outdrive with a 5L chevy engine. The prop is off a king cobra I don't know the year.
Dhadley
You should have the drive that uses the V6/V8 outboard type props which is the same as the King. If it slips on, it will work. It may not be the right pitch but it should fit. Usually in a 3 blade version the diameter will be around 14 1/4".<br /><br />Good luck!
Dhadley's right on the money....<br /><br />And, Those Same Props willl Also slip right onto the Mercruiser outdrives + V6 outboards......<br />But, The Merc Props Won't fit an OMC.........
Dhadley
Bondo -- the Merc props will fit the OMC/Cobra/Bomb motors. Simply shorten the Merc splines and away you go. We do it all the time.<br /><br />How cool, you just doubled your prop inventory!
Dhadley, You're No Doubt Right.....<br />Do you do this with a large drill or ream, Or rehub the prop ??????<br /><br />When I was playing with the two, the OMC prop slips onto my Merc propshaft, you just need a very Thin Nut to hold it on.....Although this could be the length of the Torque-Shift prop, I didn't try a regular prop.......<br />The Merc prop stopped short on the OMC propshaft by a considerable distance.......
Dhadley
Actually we shorten the splines in a mill. Most prop shops can do it very easily. No big deal.
